Alarm install questions/ need help
olds443
So this is the first remote start alarm I have ever installed. So far it is hooked up to send and receive alerts, lock and unlock the doors and set the alarm. The issue I am having is with the remote start part. I wasn't really concerned about having it but figured I would hook it up anyways being it is part of the system.
So...;
1) where does the flex relay wires go? Are they even used on an 86?
2) trunk release? Do I need to connect a relay to the factory switch?
3)turbo timer wire connects where? ( i actually get a code for this if i try to remote start the car)
I have more questions but it may be better to respond directly to my email; jverosales@comcast.net
Thanks for your help
if i remember correctly the flex relay is the thick gauge pink/black wire. that wire is not needed for your vehicle.
the thin red/white wire is the trunk release. it is negative trigger . you need to add a relay with it to function your trunk release.
make sure you program the unit from manual transmission mode to automatic. it comes default set to manual
make sure you connect the think black white neutral start switch to ground or the remote start wont function.
I'm not aware of a turbo timer wire ?? that should all work through the unit.
Let me know if you have any other questions.
Steve
