8yrs 80,000 is the warranty on emissions, I think it's gov't regulated not by the mfg's/I wonder how many catalytic converters will fail because of cold misfire because of sticking intake valves? Will they cover those too?
SignUp Now!8yrs 80,000 is the warranty on emissions, I think it's gov't regulated not by the mfg's/I wonder how many catalytic converters will fail because of cold misfire because of sticking intake valves? Will they cover those too?
It's already happening. I've done several at our dealership. BG did a demo this past Friday about their new top end clean. Gotta get something on top of those valves. Only way to see if its affective, is to do a tear down.I wonder how many catalytic converters will fail because of cold misfire because of sticking intake valves? Will they cover those too?
Boroscope can't get enough detail? That will be funny if the manufactures actually add a top end clean to the maintenance schedule. It's also surprising they didn't see this in the R&D before they went into mass production.It's already happening. I've done several at our dealership. BG did a demo this past Friday about their new top end clean. Gotta get something on top of those valves. Only way to see if its affective, is to do a tear down.
I think a lot of pressure gets put on R&D departments to get things into production. And they run into "we never thought of that" scenario's.Boroscope can't get enough detail? That will be funny if the manufactures actually add a top end clean to the maintenance schedule. It's also surprising they didn't see this in the R&D before they went into mass production.
Yea, I do have that 800.00 tool in my box!! From what the BG guy said, they are talking to GM about a service just for that. We will see.Boroscope can't get enough detail? That will be funny if the manufactures actually add a top end clean to the maintenance schedule. It's also surprising they didn't see this in the R&D before they went into mass production.
Is BG publicly traded? I wouldn't expect a car manufacturer to aquire something like this from another company very long. They much rather produce it at 1/5 the cost and sell it to the dealers for only a little less than BG. Need to find out which petroleum companies produce the top end cleaners.Yea, I do have that 800.00 tool in my box!! From what the BG guy said, they are talking to GM about a service just for that. We will see.
You'd think they would have had years of run time on pre production stuff and would have seen huge carbon deposits on the valves. I don't see how this could have been missed considering they data log just about every inch of an engine throughout their test cycles. That's a huge one that's very visible to the eye and very repetitive. I've the valves are visible with the plenum removed in most of these engines there has to be something that they can develop to spray in there and break down the deposits and suction them out. The year down labor to pull heads and remove valves could be a quarter of the cost of manufacture of the entire car. The carbon is very tough to remove from valves and takes a lot of media blasting to remove 100% of it but there will most likely be something that can be developed to get most of it off.I think a lot of pressure gets put on R&D departments to get things into production. And they run into "we never thought of that" scenario's.
Any direct port motor runs into this.
In regards to the op question. The action of alky or meth is similar to pouring cold water on a very hot gunked up stock pot. The carbon is lifted by the extreme diference in surface temperature and medium.
When I took apart my 150k mile stock block after several months with alcohol, it looked like the engine had never been run in respect to the valves, combustion chamber and piston tops.
It works as advertised and then some.
Just to be sure it is clear. Those pics are from 3.6 buick lacross with 32k on them. Seals are not the issue here. Direct injection(which our cars do not have) is the culprit.A lot of that oil on the valves is from it creeping passed the valve seal down the stem. I had that with a fresh set of champions w/o running a pcv. Also as i mentioned the fuel additives stick to the valves and bake on there hard. I had to sand the valves on turbobitts lathe while bison was prepping the heads for upgrades, wouldve taken hours to do it by hand.
