First off ..... I would like to THANK Razor for supplying the control sticker(s)
Julio understands the GRINNING..... anyways I am pretty sure this has been discussed before, but I haven't seen any pictures.... so I figure I would show you how I did my Alky controls in STEALTH MODE.....if you get your hands on a spare guage trim you won't feel bad drilling into it
for the controls... I also mounted the Bi-Colour TURN-ON LED above the TEST button,so it is inclear line of sight.
Also I have a LOW FUEL module installed,so what I did was the LOW FUEL socket contains both the Alky RED LOW LED which was routed beside the 194 clear bulb by running it over socket lip under the paper gasket ,just move the rubber grommet out of the way or cut it off, then I secured the trim ring.... LOW FUEL lights up YELLOW/ORANGE and the Low Alky lights up the same socket lense RED....DUAL DUTY alarm:biggrin: :biggrin:
