Turbobooster- The kit is a brand new Alkycontrol Razor kit-$500 plus ~80 for a three bar MAP. The owner of this company is the moderator on this site under Alcohol injection. The instruction are easy to understand and I being an accountant with average mechanical skills was able to do it. The nozzle has not been installed on my new TA33 turbo because I am porting the intake and heads over the winter. The nozzle has to be installed with the turbo off the car and on the bench. The nozzle will be attached at the lowest point on the turbo outlet just above the turbo adaptor flange on the firewall side of the turbo. The kit requires you to move the radiator overfill tank( kit gives you a new one which I installed on the fan shroud) and the old radiator overfill tank is replaced by a new one which holds the alcohol. The alcohol pump is installed on the passenger side front bumper bracket. The hoses follow the passenger side fenderwall, behind the turbo heat shield to the turbo. The wiring follows the same path into the hole in the firewall by the steering column. All other wiring is under the dash.
The low alky level and alky level of injection indicators are in the dash(Buick thought ahead and they are there). The alky power ON LED is by your boost gauge. The on/off switch fits between the radio and the dashboard. Send me a PM and I will send PICS. Thanks-Brad
