alky not coming on
SIXBANGR
mean old man
Razors kit, been fine untill now. The test button works and turns it on. But it will not come on under boost. I checked that phone jack conn. because it has come loose befor, but it is fine.
What is the voltage key on engine off at the map sensor signal wire?
found it. The plastic boost line to the MAP had broken.
Get rid of all plastic line going to the map sensor. All you need is a section of rubber hose with a zip tie on both ends.. Done.
If that jack has ever come loose.. it needs to be replaced :)
