Alky Pressures
GangsterMD
Turbo'd since '95
Hello, I have a single nozzle alky kit from Razor. I just installed pressure transducers for alky and fuel pressure so I can monitor and log on powerlogger. Can you please tell me what pressures I should be seeing on the alky side? Or what to watch for?
Darren
Enough pressure so the car shows zero knock. Whatever that pressure is.. that is your reference. IF in the future you get knock... and the pressure is still the same, its not the alky but something else.
To say your car needs 120 PSI or 80 PSI.. is all relative to your mods, fuel being used, outside climate conditions, etc. There is nobody that can say you need exactly 93 PSI at 21 PSI boost.
You want to see consistency. That can only be done through monitoring. Hence the transducer. :D
Ok. I just didn't have a clue whether it should be 40# or 100# or 250#, but I get it. Thanks :)
