the 90s are gone and things from back then should have been left there
, get a modern chip designed for alky and 93 , get a real scantool and a logger like powerlogger
you say your tuning your new alky system , is this a DIY thing you built ??
what pump? what nozzle? whats controlling the pump
diy is ok but you take a lot of the learning and setting it up onyourself and the learning curve abuse on your car will more than likely end up with engine damage
if you have a street chip thats good for say 17psi and you introduce alky ( with proper volume) then you shouldnt need to be pulling fuel at 22psi boost unless your alky volume is too much, either run more boost less alky
what boost are you running at ?? what chip are you running ?' whats the timing in the chip? ,
what boost was it burned for ? a race gas chip will have more timing and more fuel
a 93 street chip works well with alky but the timing will be low (unless its an old school 22-26degree 93 chip
turbotweak chips are adjustable for WOT fuel and timing , and if your ready for leave the old school TT also has wideband control chips and speed density chips
also get a modern monitor for tuning , the otc2000 tends to read 100mv higher than the scanmaster that we use for tuning so leaning it to 700s isnt a wise move ,
and tuning on narrow band o2 is risky , you should be tuning on KR ( as in no KR) and pickup of mPH , if pulling fuel make the car mph slower than you shouldnt be pulling fuel but safe to say if it was tuned and ran fine on the chip you have before turning the alky on you either need to pull fuel or increase the boost when the alky is introduced
oh and fYI to run 10.9s on fuel only with 42s the car was running way lean as the injectors would need to be run static (100% duty) and still be coming up short , youd need elevated fuel pressures and big cohonies (or cluesless ) to try it on 42s
