berserker6
Assistant to the regional manager
- Oct 1, 2009
Chasing something not right. Used to be I'd hit the test button in the driveway (it would bog) and the system would be "primed" and ready for the rest of my drive and I'd have zero knock. Now its become I need to hit the test button if I know I'll be in boost within the next minute or so. If I forget to "prime" a little knock shows up and I get out of it. It does still bog hitting test. So I've begun troubleshooting. I dont see a leak. I'm not losing any alky volume from the tank. Wasnt sure if alky was flowing back to the pump from the spray nozzle leaving the line empty. Or if the pump is getting lazy. No I dont have the alkycontrol tester. One thing I did see is 4.69 volts at the connector down by the pump with the controller set at 8 when hitting test.Thought I remembered reading I'm supposed to have 5 volts there? Is that the issue? Tried calling julio but hes out til 2/3
