Alaskabuick
- Jul 4, 2004
Man this is getting old my Brothers.
My car had the wrong valve springs and was floating the valves last fall. Over the winter I had the Behive springs installed on the GN1s. The car has a 212/212 roller. I do not know if the car has the 885 or 853 roller lifters (hope I got that right Race or street), all the reasearch I did points to the 853's or what ever is standard in a ductle roller cam kit from comp.
It will break up under boost or no boost at the same approx rpm.
Coil pack new and good
new Module
Have tried plug gap .35 down to .28
New taylor plug wires
crank sensor is not rubbing
AF on Fast is where it should be when I log.
Volts are good (have a volt booster, can they cause problems?)
Have ran the valves a million times, any where from 1/16th turn past zero lash 3000ths, 1/4 turn, 3/8th turn, and 3/4 turn 30,000ths.
By the way my valves terrain in very quiet even at 1/16th turn, suprising.
When the car breaks up I can hear valve terrain noise, it wants to pull up 6k without a doubt.
If I short shift the car it pulls strong as hell. When the car is left in drive to shift itself it almost seems confused when it hits this breaking up point.
I am at the end of my bag of tricks,
any ideas Guys?
Dennis
new Module
any ideas Guys?
Dennis
