Disconnect your fuel pump and run the car till it dies. Pull the valve covers and have someone crank the motor. Watch each rocker as it is cranking to make sure the valves are opening all the way.
I have a 212/212 billet roller in my car and it has been to 6500rpm.
Check the power wire going to your starter and make sure it isn't grounding itself out somehow. Mine was grouning on to the starter heat shield causing the same thing at higher rpm (must have been the vibrations). Was smooth at low rpm, but once it got into the 5k range it sputtered.
What kind of miss are you getting? Pop through intake? Pop through exhaust? Which sensor spikes first when you look at your FAST logs? (RPM, A/F, IAT, ?) Look frame by frame to see which one moves first.
