Azrial89
- May 8, 2011
Upon redoing all of the front suspension, I noticed as I disassembled... Shims just seemed to fall from the sky. Where in the world do they go?!?
SignUp Now!Shims just seemed to fall from the sky.
Hate to say it but you do need an alignment now and if you read the stickys in the section look under "Suspension recipes" to find some decent info on the specs you want.lol, they are on the bolts for the upper control arms. Whenever you redo it you have to count and put back the right amount. Now you desperately need an alignment.
So basically until I get the alignment and in the way to get the alignment, just mix and match some shims on the inboard and outboard parts of the bolts?
Unless you're really good a spacial dementions (sp) and angles you're better off towing it to somewhere that has some sort of clue on how to align one of these cars. Make sure to read the stickys so you can get some idea of the specs you want to run on it.So basically until I get the alignment and in the way to get the alignment, just mix and match some shims on the inboard and outboard parts of the bolts?
