Alpine 1.5din radio, bstc boost controller
TurboTrujillo
Have a 1.5 din alpine cda-d825 150 shipped.
Radio fits our cars perfectly.
Bstc boost command boost controller 100 shipped
Bstc boost command front
Love this radio,I have one in each of my buicks!
Glws
Interested in radio. No others frames or anything needed for install? Straight drop in to install?
Haven't seen that boost controller before. What is it?
Do you have a factory radio or aftermarket. And the boost controller has to be spliced into the wire harness right above the ecm. When off the computer controls boost and when on it intercepts the boost signal and tricks the computer into thinking it's lower boost than it is..at least that's how i understood it.
I have an aftermarket one in now that came with the car. But I can take it out easily. I have the factory one as well.
All you have to do is take the brackets off the factory radio and put them on the radio and just screw it in place if your factory doesn't have the brackets I may have an extra set I can toss in
Ok. Yeah, I'm not sure if I have the brackets. The radio is in a box the was given to me with the car. I wouldn't be able to check till Monday tho. I'd still take them tho if u don't need them
Ill have a look and see if i do have an extra set of brackets and will throw them in if you get the radio. also you can by an adapter from ebay and wire in a switch to trick the radio into an aux mode to play music off your phone.
