Lets start off the right way. The car is an 86 GN, freshly rebuilt 109 .020 over, 206/206 flat tappet cam, 60lb injectors, lt1 maf with translator, racetronix fp and hangar with hotwire kit...the basics. Fp set to 45 line off.
It always has problems, but there are two I CANNOT figure out. First one- car does not like to idle. Vacuum will bounce, and sometimes the car will die. Blms are good 122-128 at idle, maf is known to be good. When it starts to hesitate (almost like multiple misfires at once) I can watch the 02s drop to almost noything on the scanmaster, and when it gets over its moment the 02s will come back up and continue looping. Tps is set at .40 and iac is around 20 when hot. On occasion it will idle fine, but it seems now to happen less and less.
What I have tried - readjusting cam sensor, new IAC, new plugs and wires, another ignition module and coil pack, computer.....and it seems to be getting worse. Tps is good. Have also tries another maf and fp regulator.
Secondly, the car had no misfires at WOT before rebuild. Now if I go WOT, I notice that my boost fluxuates, and the car starts to sputter really bad. Seems to happen more warm than cold. Again, tried another coil and module (used ac delco I believe) and same exact thing. New plugs and wires as well. Computer is good, cam sensor seems to be working fine. Definitely getting fuel.
Please help me. I am desperate for help. This thing gives me a huuuuge headache, usually I can figure them out but these two problems have me STUMPED. I was thinking maybe the crank sensor could be an issue at WOT, but the idling problem has been happening for years.
