excobraguy
- Feb 25, 2007
Alright, so I finally have my engine in the machine shop getting the machining done..........let me know what you think it will lay down at the wheels. Here's the combo:
Std bore block (109)
Stock pistons (It's what the engine builder insisted on!)
Stock crank turned .010 under
VPE stage 3 ported stock iron heads
Ported intake
65 lb injectors
Accufab fuel regulator
LT1 MAF
MAF Translator
3200 stall Pro Torque converter
Built 2004R rated to 700 hp
Stock 3.42 gears and rearend
Front Mount Intercooler
Big Mouth CAI
RJC Powerplate
PT6152E Turbo
Alky chip from Turbo Tweaks
Razor's alky injection
TH Downpipe
210/215 Revolution X roller cam
Will be running about 22 psi with around 23 deg of timing..........93 + The alky. Thanks for the input........
Ported intake
65 lb injectors
LT1 MAF
MAF Translator
Big Mouth CAI
RJC Powerplate
PT6152E Turbo
TH Downpipe
