alternative tps sensor
V6cious
It has been awhile but I can remember someone finding a tps sensor from a vendor like i think holley that was a exact replacement for our cars, please tell me that I was not dreaming
you can use a variety of tps sensors from 3800's in the junkyards
i think i got one off a 3800 series I motor
you might have to switch pins but.. its not a big deal.
holly does!!! i got one for my hot air once and it lasted and it is on my 87 engine now and still working geat. dont remember the pn something like 35-xxx.
Re: Re: alternative tps sensor
I dont think you can do that. The hot air TPS rotates the opposite of the more common IC & 3800 TPS. I cant think of any other car that rotates the same. Looks like it is GM or the aftermarket.
Re: Re: Re: alternative tps sensor
........ i have one on my car dude
the very earliest I's have them i believe.
the same I's that have the 86/87 crank sensor on them.
i have two tps that came from a junkyard 3800. this i know for a fact.
Part# hly 543-29 $35.69 from summit.
I also went to the junk yard and found numerous tps sensors that rotated the correct way they were 20 bucks each I acquired 6 just so i would get a good one. Tried all six and could not get voltage above 3.5 so i bought the holley and it works great. The vehicle i found the junk yard tps were caddys if you were curious.
thanks for the replies I feel better that they are readily available in the yard
Originally posted by 85 ttypewh1
The junk yard ones did not work for me.
probably because you got them off caddies and not buicks like i did.
Could be, do you remember what years and models the cars were, it would be nice to have a spare.
holly does!!! i got one for my hot air once and it lasted and it is on my 87 engine now and still working geat. dont remember the pn something like 35-xxx... Part# hly 543-29 $35.69 from summit
i checked this part# on www.summitracing.com and came up with a TPS sensor for their Pro-Jection setup. in the pic, it shows a sensor with the connector angled at 90* from the two bolts. this would not work on our setups would it? hopefully its just a generic pic they use for all their TPS sensors
just wondering if anyone has this exact part and if it will fit my car. i dont wanna spend the money, have the part shipped, and then find out it doesnt work
The part # i stated is what is on my 85 which is stock in relation to the tps and yes it is angled 90 degrees to the front of the car.
ah-ha, its angled towards the FRONT. cool. for some reason in the pic i got the impression that it was towards the back. thanks alot!
