Pronto
No amount of evidence will ever persuade an idiot.
- Dec 9, 2002
Wonder why they would want to lower voltage rather than just maintain it. Seems like they almost wanted things to go boom.
SignUp Now!why would they do that or want less voltage? I think the answer is something else other than "they have circuity for that"For years I have seen my voltage drop at high RPM from 13.9 to 12.2 when over 6000 RPM using Autozone and other reman alternators.
Info from a local electrical rebuild shop said that our alts have a built-in provision which lessens voltage at higher RPM's.
I then examined my current alt, and found it had a pulley which is smaller than stock?
Having some stock alt cores, I installed the larger stock pulley which resulted in less alt RPM, and more stable voltage.
The voltage is lowered to keep from over charging the battery, extending it's life. They lower the voltage to what's called the "float voltage" for the battery which is 2.25 to 2.30 volts per cell that totals 13.5 to 13.8 volts.Wonder why they would want to lower voltage rather than just maintain it. Seems like they almost wanted things to go boom.
Would you look at it ?
I put the smaller pulley on the alternator and it picked right up.
Not only is it showing 14 volts, it seems to be running smoother.
If it's working better then keep it. How about at higher rpms?
Same here...while not a AZ it was a aftermarket 170 amp alternator and the guy put a smaller pulley on it and I was losing volts at WOT above 5200 and the pulley was spinning the alt like 15000 rpm or something like that and it didnt like that. I replaced it with a stock size pulley and all was well.
