I'd probably try this one.
"Beck/Arnley is your best alternative for alternators
Their remanufactured alternators have all new bearings, bushings, and brushes. Slip rings are replaced or remachined, and cases are polished, coated or plated with no adapters or pigtails. All Beck/Arnley alternators are clocked for specific vehicle applications and then 100% tested. This guarantees OE quality."
$130 is a lot for a rebuilt, but at least it should work and is the right 120A one.
I'd bring yours in if you order one or to compare it exactly to what they have there.
After looking at all the choices the ones without a name brand on them might be good also but I'd want to see the brand first, so going to the store is a must with that list, and a number of them being for the wrong application and all.
I'd still look for a local shop that knows what a 120 Amp. CS144 alternator is with a 6 groove serpentine pulley of the proper diameter. :smile:
