Alum Head Package w/rockers $1600!
Nick Micale
Tech Advisor
Staff member
We just removed a set of well-ported M&A alum heads from an engine being upgraded.
They have been vacuum tested good which is expected since they only have 200 miles since freshened.
Rocker and valve covers are included.
These are ready to bolt on and the price is $1650 plus shipping.
What size valves? Any flow numbers? Will they work on a 3.8? What bore would be required? What head gasket is required? What rockers and ratio?
The intake valves are 1.90" and the exhaust 1.60"
No flow numbers, but the intake port is 2" tall which is the max for a ported stock intake unless it is modified and welded for more height. This is what we use for mid-low 9 sec. builds with a ported stock intake.
No sure the ratio of the Scorpion rockers, my guess is 1.65.
No issue using these on a 3.8 bore size.
The valve springs are set up for a hydraulic roller cam.
This package using new TA well-ported alum heads, roller cam springs, rockers, and valve covers would cost ~$3600!
Really? What are you building? What did he recommended? This is a smoking deal. I just spent over 3k on my alum head setup.
Nick , I will pass. Spoke with my builder and he suggested to do so. Good deal though!!
I have for the most part been a do it yourselfer, but now i want a high 9 second 10.0 capable engine . nothing major really , steel crank, steel rods, je pistons (stock stroke) , was going to use iron but i got my butt whopped my a buddie who just put on some GN1's so i want to go with some aluminum heads now. using a 210 215 roller, He just said to stay away from the older stuff (M&A) and even really old Champion castings. I m by no means an expert. Cruz will be building it for me since he is in Florida
Right on, sounds like your going with some TA Heads then like me. I have TA's on both my motors
Very interested. Check my cash tomorrow
Heads have been solddddd
I'll buy today. 8434727499
