I have a new shortblock (Diamond pistons 0.005 below the deck 29.5 cc dish volume) and Champion aluminum heads (46 cc chambers ,1.90 int,1.60 exh valves).I would like to use a 0.027 head gasket (Cometic) thickness which takes me to 8.74 :1. Do I need to clay a piston and verify a required clearance? Does someone have experience with Cometics and Champion aluminum heads? Does someone know what kind of pushrod angle is created when using Champs,a hydraulic roller with Morels and a stock rocker on a heavy duty shaft. I'm thinking that the side loads created are just asking for a failure. Any help is appreciated.
