blackdeathtrap
smoking six barrel
- Apr 1, 2010
iv got a 87 buick this is whats done to it
1987 buick grand national ported in polished heades port matched intake , 3 inch g body down pipe ,3 inch muffler tech stainless exhaust magnaflow mufflers, tin man 4 inch intake 3 inch maf pipe ,eibach springs , shorty shifter , no drill tach moutn tach with shift light t top gauge pod oil pressure gauge and volt gauge scan master 2.1 3 a pillar pod with boost gauge temp gauge and casper knock gauge
presidential tint blacked out tail lights stainless t top frame fresh floor pans
i have major knock issue bieng cause both the down pipe hitting frame and control arm and major turbo manifold leak i also seem to have a faulty maf i found this by repairing the wire from o2 to harness which removed my code 44 and left me with a code 33 bieng a faulty maf heres a list of what im going to ad to solve my probleme
new stock headers and all this other stuff do i need anything else asuming all other sensors are good to go or should i make other up grades not to much cuz this is pretty much the end of my budget .
1 x GBodyParts.com Tubular Upper A-Arms
1 x HRpartsNstuff Poly Motor Mounts
1 x Grand National / T-Type Leak-Proof Copper Header To Turbo Gasket
1 x Grand National / T-Type Leak-Proof Copper Headers To Head Gasket
1 x Grand National / T-Type MAF Translator
1 x Grand National / T-Type MAF Sensor - LS1 3.5"
1 x 86-87 Grand National / T-Type TurboTweak Street Chip
1 x Adjustable Fuel Pressure Regulator - Billet
1 x Grand national Fiberglass Bumper smooth - Front 1981-87
1 x High Output Coil Pack
1 x Grand national t-type Fiberglass Bumper smooth - Rear
1 x Cowl Mount Fuel Pressure Gauge Kit
