psycho6cyl
Ponies Are For Lil Girls
- Feb 11, 2005
Ok in my quest to keep things as simple as possible i want to make sure i will be hooking things up right. this is a street car witb some track use. Id like to use spring pressure on the street but when i go to track use the controller. So using diagram B idea can I use the map source to the inlet on the controller solenoid on the 500? or for accuracy it should be Teed off the turbo? My map is by glove box where boost controller is. figure use just that hose.
