AMS-500 BC wiring help
buickboy
AMS-500 Boost Controller Wiring Assistance needed-
Written instructions suck so am looking for experiences on where the source of the Input 1 and Input 2 wires come from for stage 1 and 2 triggers. i going to use the transbrake switch for the trigger for input 1. Is that a good trigger? How about input 2 trigger? Must be 12V or Ground source.
Mitch
right now i have my stage one wired to my brake pedal. next weekend i will be moving it to the trans brake button so thats a good one. stage 2 is wired to the xfi output. are you running a stock ecm?
not sure on the outputs for the classic fast but im sure cal can help out. is there any RPM/TPS trigger outputs?
If the box has the NOS stuff enabled, you can use the first stage to trigger it.
Update: Thanks for all the help you guys!! I decided to wire the Input1 to the Transbrake switch and Input2 will be triggered by ground from a hobbs switch set to 2-3 PSI boost. Should work good.
Mitch
