An inside look 2004r internal transbrake
chris718
This is what it looks like installed.Automatic shift transmission with transbrake.I will be reissuing my 400 autoshift brake in march,along with TH400 LOCKUP TRANSMISSION.Will keep you updated.
400 auto shift? Do tell more, Im all ears! Or do I need to tune in around March?
Fully automatic shift 400 with modulator and governor.Put it in lo gear and push the button.TRANSBRAKE.I have made these before as you all know just not many because of no interest but seems to be a renewed interest in them.
Can you shoot me a PM on the parts that I would need for the Auto 400w/brake and the prices. I have a RMVB 400 now. This may be its only hope to stay in the car.
more info!!!!
don't see this 200 brake on your web site---what all has to be bought and changed?---$$$ also. Is it slow releasing??? I guess you would need to T in for the pressure switch if one wanted to retain it.
kit comes with 570 boost valve,seperator plate,and brake blockw/hose.$399.00brake release is fast if you have a bleed hole in the hi drum.If not its not as quik.so it is a bolt in but you should open trans and drill bleed.no deep pan needed,no crazy plumbing.I have 6.Im making the other 14 I have material for and after that if no one buys I will only offer in transmissions.
Sharp looking unit you have for the 200 Chris. Better than the other units sold by other Vendor..:D
jasjanz.It is a complete bolt in valve body.If you have a tbrake in the car now you will need to install a governor and the intermediate band .
