Well, now that everyone has had a chance to post their emotional reactions, maybe calm can prevail and science can proceed. I didn't post this to stir stuff up; anyone who knows me knows that I care about the science (and some would say little else, I've been accused of writing the longest and most boring posts on tb
). I know that Richard and his people have done a lot of research on this, I have read his website end to end at least twice and talked with Richard about oils more than once. As a Buick owner and PhD chemist (but not a material scientist or tribologist) I have a healthy curiosity and some general knowledge about this subject, and since these results seemed to me to have been obtained in a careful systematic way that I couldn't easily refute, and since they show such a surprising drop in film strength when extra ZDDP is added to the current SN oils I wanted to make sure Richard and others saw the post and had a chance to think about it and respond to the science. I have read the postings on speedtalk, where the methodology is presented, and I think it needs to be taken seriously. First, this is not that silly hand crank snake oil seller, this is a machine used in an ASTM test that applies the load slowly and systematically to a wear surface that is carefully prepared fresh for each test. The ASTM procedure was followed at first and many repetitions performed until the poster was convinced that he could reproducibly generate accurate results. He then tested many oils, performing several repetitions in each case to improve his accuracy, and repeated tests of oils over time to make sure that no systematic drift was ocurring. He did decide to use a higher oil temperature than the test specifies, to better represent an operating engine and not a cold start in his opinion. This did not change his relative rankings of about 30 different oils that he tested both ways but it does open him to the criticism of "making up his own test". He is not selling anything and doesn't work for any oil company, he just wanted to know for himself. Here are links to his earlier test reports:
viewtopic.php?f=1&t=30483,
viewtopic.php?f=1&t=30596, and
http://speedtalk.com/forum/viewtopic.php?f=1&t=31406 (hope this come through ok). As part of the discussion in those posts I and a couple of others asked about testing ZDDPlus or another additive to see what effect it had, and the link I posted first is the result of that test.
I assumed that there would be an initial wave of reactions but I really hope that we are now past that and that people will actually read those postings and think about the testing methodology and the science involved. It's not about popularity, it's about designing experiements and collecting data to confirm or refute hypotheses and doing it in a way that controls all the pertinent variables so that the experiments can be replicated and the data confirmed. If the speedtalk poster's methodology is flawed it will come out, if not, maybe current oils have additive packages that have changed composition so that they are no longer helped by additions of ZDDP and we need to know that. Or something else, but again, we need to know.
