turbojimmy
Supporting Member
- May 26, 2001
Need some help with some analysis. Got to the track yesterday for some test-n-tune. First time with the new engine. The car runs better than ever, but I don't think it's running nearly as well as it could be given my mods (see sig). It was mid/low 40's out. MAT temps were in the 50s. I'm running 275/60 BFG DRs. Varied pressure from 30 down to 20 - wouldn't hook. Running 94 octane and alky (straight denatured). All launches below were just a punch from a dead stop - no brake boosting. The DRs wouldn't allow anything but a 0 PSI launch. I could only get TLink data on the one run where the O2s were 820. I'm thinking my boost gauge isn't right. It's showing a lot of boost but no knock (last time out it was showing 24 psi of boost on 94 octane with no alky and no knock - I find that hard to believe). Yesterday, I had no knock at all except for some minimal blips on run #5. I know you can't tell me much with out scan tool data, but do the numbers suggest anything other than a lack of traction? I know it's bogging out of the hole, but that's because I'm launching at 0 boost. Extender chip, 21/23 timing (98 octane)
Run #5:
25 degrees WOT timing via T+; 23-24 PSI boost?; alky, 820 O2s
R/T: 0.744
60': 1.91
330': 5.178
660': 7.895
660 MPH: 90.33
1000': 10.286
1/4: 12.269
MPH: 111.64
Run #4:
23 degrees WOT timing via T+; 23-24 PSI boost?; alky
R/T: 0.903
60': 2.01
330': 5.324
660': 8.058
660 MPH: 89.89
1000': No Time
1/4: 12.442
MPH: 111.6
Run #2:
21 degrees WOT timing; 23-24 PSI boost?; alky
R/T: 0.765
60': 1.957
330': 5.327
660': 8.026
660 MPH: 89.36
1/4: 12.44
MPH: 110.76
TIA,
Jim
Run #5:
R/T: 0.744
60': 1.91
330': 5.178
660': 7.895
660 MPH: 90.33
1000': 10.286
1/4: 12.269
MPH: 111.64
Run #4:
R/T: 0.903
60': 2.01
330': 5.324
660': 8.058
660 MPH: 89.89
1000': No Time
1/4: 12.442
MPH: 111.6
Run #2:
R/T: 0.765
60': 1.957
330': 5.327
660': 8.026
660 MPH: 89.36
1/4: 12.44
MPH: 110.76
TIA,
Jim
