That's a pretty excessive positive offset, those wheels are probably designed for FWD applications, with a very shallow lip and a lotta backspacing.
The BS on the 10" rim is about 6.68" if I remember the formula correctly. You'd probably want 2" wide adapters to bring it down to 4.68". Usually when people do 10" rears, they go with a 4.75" backspacing, so you'd be pretty close.
8.5" fronts is fairly wide, I'd be worried about rubbing. The BS on that one is about 5.53". Probably a 1" or 1.25" thick adapter for those. But I think it'll rub regardless even if you space it correctly.
But as I said this all depends on if I'm remembering the formula correctly, which I think I am.
To calculate backspacing you use this formula:
(rim width ) / 2 + 0.5 + (offset /25.4) = backspacking
Some people use that formula without the "0.5" in there, it's just there to prove a half inch of slack in your results.
Being 100% with the calculations is pretty hard to do, there are little variables with each wheel, so if possible, you'd be better off ordering wheels that are made to fit our cars.
