SignUp Now!I think I may have to eventually convert. My Hondas put down more than that.
Ah, young grass hopper that shows how yee has little knowledge of the the Turbo Buick power curve. It's not the horsepower with these cars it's the torque and they make gobs and gobs of that. 285 HP to the wheels will get you into the 12's with some stickies.
You ricer guys kill me with the HP talk. It takes you 3 times the dollars to make power then you can't put it to the ground without constanly breaking parts. Now what fun is that? And to boot you don't suffer from a 20% power loss through the driveline.
MoeJr post the torque numbers also.
why does that get under your skin so much? i just don't get it. or, the internet being what it is, maybe i'm misinterpreting your posts wrong. if i'm taking your comments too serious, than i apologize.
You are and you are again. I was simply stateing that to the uninformed reader that does'nt know anything about these cars always make the same assumption as others that HP is king. Well compare any GN to a Supra on a dyno and it's clear to see that we won't win any HP wars. Torque moves these cars and as always if you don't make big HP numbers you can easily be underated. Just as in your statement, as I have to take it at face value what you have stated. Wether in jest or not. As you siad this is the net and I can't read emotional content through your key board. So before you go off the deep end keep in mind that I have not said anything offensive to you or called you names or any of that. I don't know what your background is or mechanical aptitude. I just made a comment in reference to your post which is very much in line wth the way many ricers think. And while your build may have come in on the low side of the scale on your Honda from my experiance you are wayyy on the low side of the norm. Most guys I know that race imports spent 3 times that amount before they get that fast so you must have some secret KFC recipe....lol.
Kaj trust me when I tell you there is more HP in a hotair than what that GN was putting out. I didn't see an aftermarket turbo on it.
as for my comments on horsepower, that's the number that was posted, so that's what i commented on. no numbers were torque were posted, so... what was i supposed to go off of?
these cars redline at what? 7k rpm? i wouldn't expect to have as much HP as TQ.
Sell the damn car and get another Honda Kaj. Save all of us the agony of another Ilive4GNS please.:biggrin:
This what I'm talking about. . . . . .
Charlie, boostmaster;
Why don’t you guys just go ahead and spill the beans on the secret "go fast" recipe instead of wasting time?
Well, since you guys won't, I will, hope you don't mind. :redface:
Here is a proven “Easy and cheap way to go fast recipe” for HA cars:
Add;
-Big used injectors (You should be able to pick a set up real cheap)
-Flat Tappet cam (to keep cost down) in the 280 advertised range with +.600 lift
-Big fuel pump to supply the fuel
-BIGGEST FM IC (Ford power stroke unit, the bigger the better!)
-BIG turbo (T70) with a 4” DP to make it breath,
-A 3600-3800 stall converter from JEGS or Summit
-A used TT chip from the board or E-Bay.
-4.11 posi rear end with slicks
. . . . . . bolt all the parts and take it to the track,
Be sure the tank is about 1/8-1/4 full to save some weight.
Shift it around 6500-6800 on pump gas at 25-27 psi boost.
Try it and post back, I PROMISE, it will go fast.
It will go fast for at least 1 pass.:biggrin: LMAO! Thanks Jerryl.:smile:
Well you can always turn the boost down to about 22 and shift at 6000 to make is last, agree?
I think what we are all trying to say Kaj is that you don't need an intercooler to get the power you are looking for.
Like I said, I'm not being mean but the expectations you have for the car and your knowledge about other brands don't mix. Please take your time and learn about them first so you have a better idea of what you're up against.
If you think the SFI HA cars are hard to find parts for or mod then take a look at the CT cars. I litterally had to make my own turbo because there's no upgrade for them. The principles are the same though. Know what the system will allow and how you can modify it for better peformance before you decide to do any mods.
I'm just gonna swap to the 87 top end. Less headaches
I want my build to be enjoyable. There will be mechanical issues along the way
