Another List Of Parts, Tons Of Nice Parts
tom robison
ALL UP IN THEM GUTZ
Here is a list of parts I have for sale. I have more parts than listed, so if you do not see it just ask and I will get back to you. I bought 2 storage bins full of parts. There is everything from stock interior parts to stage part. The number that follows is the discription is the number of the picture at the link below.
2-Stock lower intake manifolds 150.00 shipped each (2186, 2187, 2190)
1- Stock lower intake manifold home gasket match 130.00 shipped (2188, 2189)
1- Stock lower intake manifold rear cracked missing I piece to fix 100.00 shipped (2191, 2192, 2193)
1-Stock lower intake and doghouse 170.00 shipped (2194)
2-Stock doghouses 30.00 shipped each (2195)
1- Stock throttle body housing and blade only ,no iac housing 30.00 shipped (2196)
1-Stock throttle body, no iac housing 65.00 shipped (2197)
1-Stock fuel rail, slight bend a regulator 35.00 shipped (2198,2199)
3-Stock fuel rails 65.00 shipped each (2200,2201,2202)
2-Set of vacuum lines 30.00 shipped each (2203)
1-Throttle bracket 45.00 shipped (2204)
3-Cam sensor bases, 1 broke, 1 needs pined, 1 good, no caps on any 50.00 shipped for all (2205)
3-Sets of stock fuel lines , feed and return 100.00 shipped per set (2206)
1- complete stock air cleaner assembly from a25,000 mile car 75.00 shipped (2207)
2-Powermasters, 1 complete and 1 for parts condition unknown 150.00 shipped for both (2208)
4-Y brackets for a/c and alt 30.00 shipped each (2209)
2-Pass side valve cover 30.00 shipped each (2210)
2-Sets of stock valve covers 50.00 shipped each (2210)
4- A/C compressors, good compression 50.00 shipped each (2209(1))
2-Accesory brackets 60.00 shipped each (2210(1))
1-Accesory bracket, missing stud 40.00 shipped (2210(1))
3-90* bracket, Alt to Header support 15.00 shipped each (2211)
1-Belt tensioner tab broke needs welded 35.00 shipped (2212)
1-Belt tensioner good shape 60.00 shipped (2213)
1-Belt tension polished 80.00 shipped (2214)
3-Power steering pump 45.00 shipped each (2215)
1- Belt tensioner pulley 20.00 shipped (2216)
1-Stock coil pack bracket 30.00 shipped (2217)
1-Turbo shield has been cut for downpipe clearance 30.00 shipped (2218)
2-Turbo support bracket 40.00 shipped each (2219)
1-Stock shifter 25.00 shipped (2220)
1-Windsheild wiper parts 50.00 shipped for all (2221)
1-Stock electric cooling fan 60.00 shipped (2209(2)
1-Stock electric cooling fan, wired for high only 40.00 shipped (2210(2))
1- Hooker header downpipe Make Offer (2211(1)
1-Home made downpipe, External pipes have been cut off and dented for frame clearance. 125.00 shipped (2212(1),2213(1), 2214(1))
1-Used hot wire for 2nd pump, has hobb switch 20.00 shipped (2215(1)
1-New front chrome alternator cover 50.00 shipped (2216(1)
1-Used manual boost controller 20.00 shipped (2217(1))
2-Used stock alternators for cores 20.00 shipped each (2218(1))
1-NOS upper console piece Blue in color Part# 25520898 225.00 shipped 2219(1))
4-stock balancers 65.00 shipped each (2221(1))
3-Stock oil pans 75.00 shipped (2222)
Stock Front Covers 30.00 shipped
2-sets of used oil cooler lines 25.00 shipped each (2220(2))
1-Stock crank pulley spacer 30.00 shipped 2221(2))
1-Stock crank pulley spacer w/ pulley 50.00 shipped (2222(1))
1-Turbo oil return line 50.00 shipped (2224)
Stock main caps 25.00 shipped per set (2228)
Oil slingers 5.00 Shipped each (2227)
1-oil return fitting for the block 10.00 shipped (2229)
Oil blocks for oil feed to turbo 10.00 shipped (2230)
1- set of ta knockoff headers , needs clamps 75.00 shipped
2-sets stock exhaust manifolds have been fixed 125.00 shipped per set (2220(3))
1-Stock TV cable 65.00 shipped (2221(3))
Stock pushrods and rocker assemblies make offer (2222(2))
1-set stock intercooler brackets 40.00 shipped (2223)
1- Drive side intercooler bracket modded, can be put back to stock easy 25.00shipped (2224(1))
1-stock up pipe 30.00 shipped (2225(1))
1- new oil pump spacer 15.00 shipped (2226(1))
1- oversized up pipe for stock intercooler 40.00 shipped (2227(1))
ARP studs and bolt sets used 40.00 set shipped (2223(1))
1-set front lower frame braces 40.00 shipped (2224(2))
Multiple Dash gauge bezels 35.00 shipped (2225(2))
1-Radio Plate 25.00 shipped (2226(2))
1-Used Grey shifter handle 25.00 shipped
Multiple shifter plates 20.00 shipped (2223)
1-Shifter plate w/ 4 speed custom plate for pro stick sifter 30.00 shipped (2224(3))
1-Blue center console complete , driver quality 200.00 shipped (2225(3),2226(3))
1- Gn center console , has been cut up for race car 100.00 shipped (2227(2),2228(1))
Multiple sets of blackout and chrome taillights 75.00-125.00 per set (2229(1)
1-Gn header panel, small crack ,easy fix 225.00 shipped (2230(1),2231)
2-Complete sets of spoilers 135.00 shipped each (2232,2233)
Qtr glass sets 50.00 per set (2234)
Stock wiring harnesses 150.00-250.00 shipped
2- sets of front aluminum bumper brackets 35.00 shipped per set (2235)
1-test pipe coated 40.00 shipped (2236)
2-Underdrive pulleys, Crank and alternator , 40% under drive 100.00 shipped per set (2237)
1- Set of Victory Titanium intake , Inconel exhaust valves for TA SE heads 1.94/1.57 500.00 shipped (2238)
1-set of used 6.5 off center carrilo rods wide journal 400.00 shipped
1-set of used 6” K-1 Rods 350.00 shipped (2239)
2-New SFI CAT flex plates neutral balanced 45.00 shipped (2240)
1- New 86-87 Gn emission tubes ¼” and 3/8” Part #bu01013-oe 15.00 shipped (2241)
1- Set of black NOS Left and Right Door handles. 1 is missing the box 75.00 Shipped (2242)
1- set of NOS door and trunk lock set , Includes 1 key in oem boxes 50.00 shipped (2243)
1- Oem Blue shifter handle in Oem box. Part #22525554 40.00 shipped (2244)
3- Gm Timing tensioner bolt 5.00 shipped (2245)
1-Set of used 3.820 hypereutectic pistons on reconditioned stock rods 150.00 shipped (2246)
1-Set of used 3.830 10-1 comp forged trw pistons on reconditioned rods 100.00 shipped (2247)
1-Set of Grand national Front and rear seats no tears, need cleaned 400.00 no shipping (2248)
I also have stock fenders , doors, full quarter panels that are rust free, seat that need recovered, interior trim and panels, Blue dash panel and a set of t tops.
Here is the link to where the pics of the items are.
Buick Parts pictures from entertainment photos on webshots
Thanks for looking. Tom Robison
i set bumper brackets need head studs 85-84 and main studs for 86-87 im also looking for a crank balancer with the windows for crank sensor 86-87 metal vacuum block shifter plate what are you selling?
ill take them take paypal ?
ill take them
pm me your payment info
Do you have picture for this. If not could you take one?
Does this have everything with it to attach it to the shifter? Do you take PayPal? If so, and if it is in good shape, I will take it.
PM sent
bumper
1 set of front aluminum bumper brackets $35.00. just pm paypal info.
I'll take it. U take PP? PM me if u still have it. Thanx.
Here is a list of parts that are sold
Intakes
Accesory brackets
Balancers
Lock set
Belt Tensioners
Turbo support brackets
Turbo Sheild
Blue Shifter Handle
1 Y Bracket
Both sets of bumper brackets
Oil Cooler Adapters
Oil feed blocks
Double Pumper wirng
1- Gauge Bezal
These parts are pending
Vacum line
Header Panel
1- set of tail lights
1-tailight
Thanks guys
Price (if you have one) on a non power passenger side door shipped to 02148. No rust!!!!
