blacknight80
- Dec 26, 2013
hey guys,
I have been picking away at swapping out my carb turbo top end with the hot air goodies and I can't get it to start. I followed the no start chart in the sticky and when I check the connected voltage of the crank sensor it is zero. When I check it with the sensor disconnected on the ignition module side I get 7 point somethin volts. Is this typical of a failed sensor. I have an 87 sensor on the way but I thought I would run it passed the pros to be sure. I tried on both the male and female sides of the connector and get zero.
Thanks,
Cody
Thanks,
Cody
