Mike T
- May 3, 2013
I have a new GM old stock sensor in my car that started making a ticking noise. The noise started at around 5000 miles.
Out of curiosity I put a worn cam sensor in the lathe (chucked at the drive gear) to determine if it was vertical or horizontal shaft movement causing the noise. Immediately you could see a tremendous amount of run out. The entire sensor body at the cap end was moving approximately .065
3 sensors total were checked with the same results. All were ran in my car which has a little higher than normal oil pressure so I assumed possible bent shaft.
Upon disassembly I finally found that the drive gear and the shaft are nowhere near a perfect slip fit.
It would appear that the roll pin is all that determines how straight the gear to shaft alignment is. My theory is once the roll pin has been exposed to stress the gear gets locked at a crooked angle to the shaft.
More variables here but I believe the drive gear is pushing off of the cam gear causing the shaft to wobble in a elliptical pattern.
