I'm rebiulding my motor, and its out as of today, since i have it apart is it necessary to replace any sensors??? (knock,map,cam,crank,tps) or any sensor
TIA,
Bryan
no unless it is broken.....like most electrical parts they work or dont......if they do it isn t really going to work better by replacing it.....(atleast in most cases)
Besides they are all pretty easy to get to....
Spend the $ where it counts......
ps, check the cam sensor rotor to make sure its tight......and check the gear for wear....I ve never seen one worn at all....
