yamahamoon
Turbo Brick Newbie
- Jan 8, 2008
Hi Folks,
Well, I got some time to dig deeper into the GN we purchased back in December. One of the nagging problems we had is that the car wouldn't shift under WOT. I dug around in the various forums, and the general consensus was that the governor spring was probably missing, and that made sense to me.
Turns out, there's another possible cause for failure to shift at WOT that I found while checking the governor spring (which was happily sitting right where it should have been): the filter was missing its seal! Pulled it out, no seal on the output tube. "Hmm, must be stuck up in the valve body." Um, nope! It was gone. "I'll be..." Put the new filter in with its seal firmly in place, and voila! Shifts like a dream at WOT now. I'm actually a bit surprised the thing worked at all; must have had just enough suction to keep pressure in the system under normal conditions, but couldn't pull enough fluid to shift at WOT.
Cheers,
Bob Moon
Cheers,
Bob Moon
