There was a thread not to long ago about putting in a on/off switch in line with the pink/orange wire so that the antenna didn't have to go up every time. Is there a prefference on which wire to use? Thanks, Drew
I would choose the wire that will be closest to the switch (depending on where you mount switch) for less wire to run but either wire will work. Radioshack carries swtiches that will handle up to 30 amp draws that will work just fine for the antenna relay kill switch.
