The car is starting to get into the realm of needing some rear suspension upgrades. I'm still using the stock GM 4 link setup. Never really had to concentrate on suspension before. Now the need to is high on the list.
Boxed lowers.
Poly bushings.
ATR sway bar.
One right side air bag. 25 psi.
Front lower control arm mountings are adequately reinforced by a X-frame member I fabbed up years ago.
I recently ordered a set of Currie uppers to try and get the car to settle down in the back a little. Hopefully taking the bind out of the poly bushings setup that's helping to hold the back end high, with the ball joint that's built into the front end of the Currie upper.
The problem I'm running into on a hard launch is body roll and the rear suspension appearing to steer the car off the line while the front end is in the air. I'm thinking I need more roll bar. What are the options for roll bar kits out there? Other ideas too?
Boxed lowers.
Poly bushings.
ATR sway bar.
