Anti submarine belt mount ?
dynoman
I just got my new 5 point harness and want to know how you guys are mounting the anti sub belt to the floor ? Is a 6"x6" 10ga. plate and eyebolt sandwiched on the floor ok or does it need to go to the frame via a cross bar ? Thanks , Sam
Pronto
You're very kind. Some day it will get you killed.
#2
I made a bar shaped like a T that connects the front bolts and put the eye bolt on the short leg. Pretty simple set up.
pacecarta
MAGNA
Staff member
#3
move seat forward , at rear of seat drill hole in floor , secure tab with 3/8" or better bolt and 2" washer under car
NY Twin Turbo
All the good stuff.....Times 2.
#4
Don't know if it's legal. But, 1 big fender washers from the bin at Home Depot under the floor pan. Then 2 regular washers top and bottom. 3/8" grade-8 through bolt and a lock nut.
Never has any of the tech inspectors check the sub-belt install when I have gone to the track. But maybe sometimes they do?
Either way, with a factory style seat, with no hole cut in the bottom in the crotch area, this belt doesn't fully serve its purpose.
dynoman
Thanks for the ideas, I always think overkill on this stuff so it's good to know I don't have to go over board . On the thought of the stock seat and the belt not fully serving it's purpose, I see what you mean . Plus the thought of " the boys " getting a running start before encountering the sub belt pains me .
#6
If you're using a five point, you really should replace the seat with one that has the facilities for the anti-sub strap for the belt to work properly.
NY Twin Turbo
#7
I have the factory offered Lear Siegler front seats. So I'm able to run the sub-belt through the seat at the seam between the extendable cushion. This is better........but not perfect. It should still go through about 4-6 inches further back. So yes, you are correct. Like so many other things.......it's a compromise dependent on how often you plan to race it, I guess.
