W
Wilson
Guest
This is from Ramchargers.com (http://www.ramchargers.com)
Image:
http://www.ramchargers.com/IMAGES/518VOLTBT.JPG
*Image is kind of small, so go to their website and look it up. They have a larger photo of it.
Description:
518VOLTB $ 69.00 The Volt Blaster will raise the voltage of the alternator to 15 volts (it is adjustable) at WOT. this can provide a subs tainsial increase in fuel delivery by increasing fuel pump o utput and increse spark by delivering more voltage to the coil. Highly recommended on supercharged and turbo applications.
This device watches the throttle position and when above a certain position, causes the alternator to raise voltage by about 1.5 volts. This little device helps the fuel pump to run a little bit stronger at WOT and to help solve fuel starvation and weak ignition problems.
Great little mod for you turbo/supercharger guys, I bought it used but never installed it on my car. I figured it probably wont do me much good since my car is NA. Anyone interested?
Im looking to get $35 bucks for it.
Image:
Description:
