Any std Turbo Cranks out there?
DSEROVY
TurboBuick.Com Supporter!
Looking for a Turbo crank.
I would prefer std/std, but would run a .010/.010.
Thanks in Advance - Dan
Yes, external balance is stock.
I have an "unknown" engine in my beater car that I snagged off of Ebay.
The main seal leaked like crazy, and when I pulled the pan to replace the seal it was obvious that it had been balanced before.
There are unknown pistons installed that are definitely not stock, although I could not see any markings on the underside to identify them.
The rear main bearing is a .020 under and is not in the best of condition.
I have a set of (ancient) ported irons and a NIB ATR hydraulic cam that I bought in the 90's that I was going to slap on just to see what I can do with the old girl. I figured getting a std turbo crank and having the balance fine tuned would be the most cost effective way of getting some more life out it.
Doesn't eagle sell an external balance crank. That would be the cheapest route if your going to balance anyway..
Putting ported heads and roller cam on a used 30 year old std crank might not be the smartest option..
Line hone with studs should be considered....
Did you want to do this before you took the engine out?
Did you repair the rear seal leak?
