Anybody running Dual Spal fans and SMC kit?
  • Thread starter Thread starter Famlycar
  • Start date Start date
F
Famlycar
Guest
If anyone is running the Dual Spal fans and SMC alky kit I sure would like to see a picture. I'm going to be putting both of these items on and would like to see how the fit is. Thanks.
NO pics:( ,,but I made a bracket that is like flat stock --the bracket is about 9" long x2"wide x1/8"thick and hangs from the2 bolts that hold the turbo cover on ,I gae the bracket a slight bend so that the alki is mounted level
HTH
No pictures either, but my flat bracket mounts to the mounting studs that was on the brackets supplied with the fans.
My bracket looks like a top hat with small brim.
Gary
I made brackets top and bottom and hung the bottle to a strap that runs between the brackets that I made. Used aluminum strap from Home Depot to make it easy.
