SignUp Now!Would the car be to stiff?
Sway bars do nothing to the ride of the car. Look at them as an auxillary spring. Well it would be firmer through a fast corner but in straight line driving it wouldn't effect the ride much.
IMO big sway bars on both ends of the car are over kill and actually hurt the handling. Put a big bar on either end but not both for the best results.
Ran around for years with the 34/36 up front and the old Herb Adams 1.5 in back. One oversteering pig. Removing the front bar made it damn near neutral through a corner. Hey I agree the bars need to be matched. But this combo(36/HnR) aint matched. You fail to mention what you are going to run for springs. Like I said the sway bar is just an auxillary spring. You don't need big bars with stiff springs. Bigger everything aint neccessarly better.
What are your goals? Straight line hook or ZR1 speed through a corner? Learn how to drive the car and you may not need some of these bolt ons. I ran around for years in Solo2 with the stock parts. Understeer? Heck just give it a ton of gas and let the rear kick out. It may not be the faster way around a corner but I didn't have to spend a dime doing it.
You fail to mention what you are going to run for springs.....What are your goals? Straight line hook or ZR1 speed through a corner?
