Anyone have an extra turbo to DP gasket?
I have a flex seal brand new in the package if you insist on using one.
Im belt sanding mine right now. Then I will use the hi temp silicone. hard to believe this silicone will handle 40psi+
Boost and back pressure ratio is ideally 1:1 ......But that is hard to do. Im going to say mine is around 2:1, so that puts me around 40psi out the exhaust.... Give or take.
Are you talking about before the turbo??
if so before turbo i can see how the backpressure would be high but the location in question is after the turbo going into a DP.
if you had that much back pressure there it would due to a clogged cat or bananas in the tail pipe.
The choke point is the turbo it self after that it should be a free flowing exhaust system
i was amazed on my factory setup there was nothing anytwhere, headers, turbo , nothing,
And that's how I reinstalled mine. Surprised how many don't. I don't think it leaks but never really tested it. Not really sure how I could without taking rockers off??
