SignUp Now!Why not call RJC or use the search function?
........... My hopes are that it will allow enough air flow through the core to still reach the radiator. Have you performed any mods to your car to enhance air flow through the cores?
~JM~
Well I got it done. Not too bad of an install after you remove all the OEM equipment that is in the way. That was the hardest part. I was a bit dissapointed to find out that my Kirban cross-brace needed to be removed to clear the tubing, but that would most likely be the case with any FMIC. This IC is truly a quality piece of equipment & fits perfectly. Can't wait for some nice enough weather to go for a drive. Thank you for the replies & thanks to RJC for producing such a nice product.
~JM~
~JM~
Which one did you go with? Part #. Let us know how it works when it gets warmer out with A/C. I too want to get one, but would like to know about water temps first.
Otes.
Otes.
