Anyone have problems with .020/.020 cut?
Black Demon
Brick Maker
May need an undercut after a wiped thrust bearing. (.010/.010 now)
Anyone have any problems?
Mike
I've heard of quite a few cars going 10's with .020/.020 cranks. Avoiding detonation is always the key :cool: .
-GNX7
10 on rods 20 on mains and a cut on thrust faces here Mike.
Give me a call. I am interested in what your crank is like when you get it out. I also have some bearing part # 's if you need them.
We need to figure out this thrust bearing thing. It's terrible!!!!
Tim Cucci
Tim Im on my 3rd thrust and after about 25 passes it is at .oo6
when i assembled it was at .oo4.I reduced my tranny line pressure
What main bearing do you all use on a 0.020" cut? Apparently the high performance bearings (Clevite MS960H or MS960V and Federal Mogul 107M) don't go beyond 0.010".
Thanks,
Buzz White in Houston, TX (sumnerw@flash.net)
Thanks, Tim.
That's what I have sitting in my garage waiting for the crank to be turned. I was hoping that someone had a line on a high performance bearing for 0.020". Anybody ever use King MB-443-AM? It's supposed to be an aluminum-tin-copper alloy but I don't know how it stacks up against the Clevite MS960P.
Later,
