LAMMONS0003
- Nov 11, 2010
I have two 84 t types. One is a running car with original ingition module. Just bought the other due to it not having any spark. It has a new ignition module from O'Reillys and an adapter that requires you to remove the resistance wire and install new wire in its place from caspers. I also have the hot wire/ relay style adapter, I can not get the ignition module to work on my running car for anything. Tried both adapters. This is a new module that i have had checked also just to make sure nothing was wrong after first time I installed it. I also have 3 other used / junk yard modules that tested good that wont fire my normally running old igniton module car . Surely two adapters and 4 modules cant be bad?? I can rule out cam and crank sensor and ECM due to the car runs with old module. Does anyone have any ideas or am I just over looking something. Please any suggestions would be nice.
