Wow, I need to update my profile, I haven't worked at Cardinal's Nuc. Pharmacy in 3 years or so
I went back to school and just finished my Master's degree in Mech. Engineering. Currently I am "semi employed" doing research and post-grad work at the university, contemplating continuing on for my doctorate, or going to work in industry for a few years before going for the PhD. I've been looking for work, but as I'm sure many of you have found out, its a tough job market out there. I could afford to buy a hone if I need to, but if i can borrow one, it seems like a waste of money, especially while I'm on such a restricted budget (i've been responsible and have savings, but want to keep them lasting as long as possible).
the more I've read/heard I was wrong by saying the knock sensor caused the problem. It was pointed out that since only the one piston was damaged it was likely something else. It wouldn't surprise me if that injector was clogged/damaged, when I pulled the old ones, they were in sorry shape. I already have a brand new set ready to install (and new harness), so if that was the problem, hopefully its been solved. Either way I'm sure having no ability to pull timing in the presence of detonation didn't help the situation. I know fuel pressure was good (43 psi initial, tracks pound for pound with boost), and I am running factory boost levels (verified by an aftermarket boost gauge, not the stock POS).
When I pulled the old piston out yesterday, i looked at the bearings pretty closely, they dont show any unusual wear/damage. No serious scratches, no bits of metal embedded, no copper showing. The rod journal on the crank looks the same, in real good shape. If that bearing had looked bad I would have opened all the other rod ends to check theirs, but since this one seemed in good shape I am hoping/assuming the other ones are too. I'd rather not crack open the other rod ends if I don't have to... I figure the more things I take apart, the more chances of me screwing something up putting it back together
