Gen 7 according to...
instructions-Micro-soft-95,98,NTor 2000
intel pent.-166mhz or faster
32MB of RAM, 64MB recommended
Monitor resolution of 640X480 Pixels, 800X600 recommended
if installing CalMap from CD, execute the program "Setup.EXE" from your computer's CD-ROM Drive. If from floppy, Setup.EXE from the floppy drive.
Select the desired location to install CalMap and the associated run-time engine into.
Click "Finish"button on the screen after selecting the installation locations. If installing from a floppy disk set, insert additional disks as the computer asks for them. when installation has been completed, a message will be displayed indicating that the installation has been successful. A window on the scren will appear w/a shortcut to the CalMap executable, as well as to the error code description file, and the Uninstall program for CalMap. Double click on the shortcut to
calMap to run the program.
In order to communicate to an ECM, the CalMap Communiction Cable must be powered up in a "key on" or 'running" mode in order to communicate properly w/CalMap.
Does this helpl?
![Cool :cool: :cool:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f60e.png)
