Saw this on an episode of Gears..... by Phoenix brake systems...it's supposed to allow you to bleed brakes by pushing the fluid thru the calipers....which is supposed to eliminate needing a 2nd man to pump the pedal and also it's said to be more efficient than gravity bleeding because the air wants to travel up thru the master cylinder....I believe it's also good for bleeding hydraulic clutches...
Brakebleeder - Maxpro [MAXPRO-205]
Although pretty pricey.....
But then this one is cheaper but has me wondering what it doesn't do that the Max pro does...
Brakebleeder - V-12 Brake Bleeder [V-12-205]
