Anyone use the wiper bottle for radiator overflow?
2QUIK6
Turbo Milk Jug displacmnt
When using the stock radiator overflow for the alky bottle, has anyone used the wiper fluid bottle for the raditor overflow instead of strapping a coke bottle somewhere?
Did know if the long distance from the rad cap to the wiper bottle would cause any problems, and the wiper bottle is already rigged with a tube from cap to the bottom, just got to remove the screen.
Trying to figure out a way to not add an extra bottle and get the volume of storage for the alky that you get with the stock rad overflow bottle.
Guess you could. Dont think there would be a problem. Cept you'd lose the WW tank.
The kits I sell come with a small mini-overflow for that purpose.
HTH
Hey Julio, I was just looking for an alternative to having another tank/bottle under the hood. The WW fluid that was in my bottle was the factory original fluid from 17 years ago up until last year when it was finally completely evaporated!! It never driven in any kind of weather or wet conditions, so its always sparkling clean :) So no reason for me to have it if it will keep me from having another bottle under there. I had emailed you a couple of weeks ago to see if you had a large container for the driver side that would replace it.
Once I get this turbo to where it will controll boost at low levels as well as high levels, I'll be getting one of your kits. Hopefully before March.
