Now that the Gen2 Translator has been available for a while is anyone using it with alky and using the Wide Band AFR tracking feature?
Curious to know if you are just using the base fueling and not using a trigger wire to tell the Gen2 to use leaner programmed fueling when the alky is on, how quickly the AFR tracking is adjusting the fueling for the added alky to maintain the programmed AFR??
