Hi! Well, Everyone Has Installed A Stock Regal Vacuum Booster On A Supercharged Buick V6, Including Ourselves. Vacuum Boosters Need Vacuum, And The Higher Ther More Pressure It Can Push Against The Master. We Have Rebuilt Tens Of Thousands Of Vacuum Boosters In Our 57 Years. We Even Build Them For The Handicapped Guys With Wheel Chairs. The Weight Of Their Hand On The Hand Control Can Stop A 6000lb Van. Great. The V.a. Requires A Vacuum Pump To Go With It, To Supplement The Vacuum Booster(?)s. We Sometimes Add 2 Extra Vacuum Boosters, Truck Style, Downleg Of The Original Booster To Crank Up The Pressure. O.k. Still Requires Vacuum. Vacuum Boosters Are Designed With A Certain Number Of Sq.inches Of Dia. Area. For Example 75 Sq. Inches. So Now, Vac. P.b.'s Are Rated To Operate At 20" Of Engine Vacuum. So 20" Times Those Sq. In. =1500psi Push Against The Master. Now At 10" Times 75 Sq.in = 750psi Push Against The Master.. O.k., Now At 0" Of Vacuum Times 75 Sq Ins. =0 Psi Push Against The Master= Nothing. You Have To Push It All With Your Leg. Turbocharging A Vacuum Booster Will Not Deliver Anty Brake Pressure, Except That Which Your Leg Muscle Can Push. It's Not Enough To Hold This Much Car. It Would Be Like Flying A 747 With A Tiller. Try It. The 747 Uses High Pressure Hydraulics. My Point Is The Hyroboost At Idle Pump Speed Delivers 2000psi To The Calipers With A Firm But Powerful Pedal Feel. It Uses No Vacuum, And No Electricity. The Faster The Pump Spins The Harder The Brakes Will Hold.
