SignUp Now!Your right! Come on guy's im thinking of trying some, need to know the do's, and dont's.From what I understand, there are some, but they're awfully shy.
Are they class racers? :biggrin:Ive used a wet kit setup in the past..... car was running over 100 in the 1/8th at the time but Im not going to post much info about it...
There used to be a few hidden direct port intakes running around... I unfourantly had to sell mine due to money issues, but as far as I know there is still 3 of them running around
You guys are so sneaky! :tongue:
The nitrous will cause the boost to shoot up on you.Dont need it for spool up, i just was wanting to know if someone is running me down i can shot a little in top gear to get away! Im running meth/ 91-93 oct. Will i need to drop boost?
Did you happen to sell yours on ebay?? I saw one proabbaly a year ago on there. It was awesome. both lines came in from below the cool to the lower intake. No one would ever see it!! It was a very nice looking piece!!!
That would work very well where the ecu was programmed to richen at the signal that the nitrous system was activated, but how would you do that with the stock ECU?Assuming one has enough supplemental injector flow, a dry setup with a programmable ecu(xfi,bs3) is the only way to go. No fuel solenoid to worry about, and jetting is as simple as adjusting a fuel map with a few keystrokes.YouTube - Nitrous Fail at Shakedown @ E-Town 2009
Whoa! That is why you build as many safeties into your system as possible. Even then, a stuck solenoid can ruin your day real quick.
Scott. Do you know what the failure was that caused the explosion?
